2
This discussion topic has been answered Discussion topic: Sky system down?
This message was authored by: Scottie0087
Sky system down?
Connected without Internet
Re: Sky system down?
@Scottie0087
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@Scottie0087
@Scottie0087
Have you rebooted your broadband hub at the mains ?
