2
This discussion topic has been answered Discussion topic: Broadband connection.
This message was authored by: SJ617
Hello. Firstly, I am not technologically minded so please excuse me when I use basic (and possibly wrong) terms.
I had a new router a couple of weeks ago when I was connected to the new fibre upgrade. It's worked fine till this morning.
The four green lights on the router are lit. But on the white BT box on the wall, one of the green lights above LOS is off. Could this be the problem? If so, what do I need to do.
 Thankyou very much.
Avatar for SJ617
This message was authored by: SJ617 Answer
Re: Broadband connection.
It worked!!!  Switch it off; wait an hour; then switch it back on! Thanks very much for your help. Much appreciated.
@SJ617 the white Openreach box is an ONT and the LOS (loss of signal) lightvshould be unlit it shows red when the unit is not getting an optical signal.To help this page explains what the hub lights mean https://www.sky.com/help/articles/hub-lights-explained-start
The fact that you have 4 green lights means the hub is connected but nodata is flowing. There is a fault at Sky's end that can cause this. The way around it is to power down the hub for an hour and the restart it when it should get a working connection.
Avatar for SJ617
