4
This discussion topic has been answered Discussion topic: Sky stream, new router 4.2 with sky fibre no phone connection
This message was authored by: Willoz
Hi all, got engineer this morning installed the new 4.2 router for fibre, there is a VOICE light which he says will come on when the phone connects - the phone is connected into the back of the router but currently I have no landline phone? Any ideas why or how long it takes for things to "talk to each other?"
Re: Sky stream, new router 4.2 with sky fibre no phone connection
@Willoz try rebooting the hub to see if it will pick up the landline. If still stuck tomorrow call Sky.
@Willoz If you have been transitioned to a Digital Landline, voice light is green, if so then takes 24-48Hrs for the old to gel with the new, any longer then get onto sky right away, neighbour waited over a month with a green light on as she would not listen to any advice, then it took sky 3 day's further to sort it out there end!
Avatar for Willoz
Level 2 icon
Thanks have rebooted router and now all working. Had to figure out number too!!
@Willoz Here is the info link to all the sky options for and if you need it next time!
https://www.sky.com/help/page/broadband-digital-hub
