7
This discussion topic has been answered Discussion topic: Sky says signal good, speed check says not
This message was authored by: Sealand1
TV is pixelating and then goes off, like signal drop. Sky says signal good, and we generally get 60mbs, but checked today and best was 36!
This message was authored by: cookiemonsteruk Answer
Re: Sky says signal good, speed check says not
@Sealand1
If you have a black sky hub could you post your router stats
@Sealand1
Avatar for Sealand1
Router stats? Not sure where they are. We did turn box/puck off and on again and it seems ok now! Thanks anyway
Avatar for Sealand1
We do have a sky puck and LGTV, nothing else
This message was authored by: Doc5907
@cookiemonsteruk wrote:
@Sealand1
Just FYI @cookiemonsteruk  when I click on that link it just sends me to the broadband home page.
Sky Q 1TB UHD
LG TV
Sky Mobile
@Doc5907
Same here.  I didn't check to  see if  the link redirectef properly. Has it been removed?
@Doc5907
Still linking to home page
Sky Q 1TB UHD
LG TV
Sky Mobile
@Doc5907
Dropped a note to kev.  I notice its not showing on pinned posts so i may need to delete the template
