Discussion topic: Sky router
This message was authored by: Paul994
Message posted on 08 Aug 2026 01:50 PM
Sky router
To get in my sky router I hav pit in
username. admin
password ( my WiFi password) says incorrect
Anyone got any idears
Find out more
Message posted on 08 Aug 2026 01:55 PM
Re: Sky router
On some older ones the password is sky
If that doesn't work either then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
