Discussion topic: Sky router has power and wifi lights green but no internet light at all. Have reset and rebooted at
This message was authored by: MJT
Sky router has power and wifi lights both green.  No internet light at all despite several resets and reboots. Although did flas intermittently orange earlier today.  Internet essential for work, can you help please. Thanks.
Re: Sky router has power and wifi lights green but no internet light at all. Have reset and reboote
@MJT run the My Sky connection test over a mobile connection as that will tell you if their is a known area fault. If there isnt call Sky to reportvthe issue.
However you need to be aware thst you use the connection for work does not increase the priority to fix what is sold as a domestic connection and Openreach are extremly budt due to the number of faults the recent bad weather has caused so it could be some days before they get round to your line.
Avatar for MJT
Thanks Chrisee, have run the rest and no known area fault.  Can you direct me to the number I should call to report the issue please.
