Discussion topic: Sky q second boz
This message was authored by: Yozzayooze
Sky q second boz
Every night although on fastest broadband always lose connection to main sky q box between 2100 and 0400. This is poor asrvice
Re: Sky q second boz
@Yozzayooze if you lose a network connection between the hub and your Q box call Sky report it as they should either provide a booster or send out an engineer to check thecsystem. The speed to your hub is not relevant it is the speed of the WiFi connection between the hub and the Q box which mstters which is mainly down to the layout of your home and how it is built.
