Discussion topic: Sky not working
Message posted on 24 Nov 2025 07:09 AM
Sky not working
My sky is not working how do I fix it
Message posted on 24 Nov 2025 07:21 AM
Re: Sky not working
@glen+mcculloch
Presume you mean broadband because there is a Glass issue this morning.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
