Discussion topic: Sky not working properly
Message posted on 25 Jul 2026 09:36 PM
My internet keeps stalling on m
Message posted on 25 Jul 2026 09:38 PM
Re: Sky not working properly
My sky has been buffering for a couple of days
Message posted on 26 Jul 2026 06:52 AM
@Lisamarie44 modt likely issue is poor WiFi signal in the area you arecw atching Sky. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
