Discussion topic: Sky max
Message posted on 22 Aug 2026 09:05 PM
Sky max
Message posted on 22 Aug 2026 09:44 PM
Re: Sky max
@Cassandra1234 sounds like you need an extender. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
