Discussion topic: Sky max
Message posted on 19 Aug 2024 07:27 AM
Sky max
I upgraded to Sky max router the internet speed is very slow it drops from 68 to 52 the a engineer comes out it lasts a few weeks at 68; then drops down to 52 I ring up Sky a tec guides me over the phone we get the speed back up to 68 lasts about 4 weeks now went off came back on speed 52 .Any suggestions
Message posted on 19 Aug 2024 07:46 AM
Re: Sky max
@ellymay122 very unlikely to be due to your new hub its far more likely to be a line issue. However unfortunately the white hubs dont report their connection stats like the older black type so forum members cannot see what is going on. Best advice is therefore to run the full connection test in the My Sky app or website as that will show connection speed history and can book an engineer if it spots a fault.
Message posted on 19 Aug 2024 07:49 AM
Re: Sky max
My sky app is saying 52 All the time
Message posted on 19 Aug 2024 08:05 AM
Re: Sky max
@ellymay122 if the app is not offering an engineer it is probably because the minimum guaranteed speeds for your connection is lower, Openreach often will not accept fault reports unless speeds drop below the minimum speed or the connection is very unstable. The kit in the cabinet could well have dropped the speed to stabilise the connection which is exactly what it is designed to do howevercwithout being able to see the stats i cannot be certain.
The speeds copper lines can support do vary as the external conditions like weather and the levels of electrical interference change it is unfortunate where a line used to perform well but now is less good but unless Openreach accept a fault there is nothing you can do about it. You can ask Sky but it is not something they control.
Message posted on 19 Aug 2024 07:19 PM
Re: Sky max
Sky are sending an engineer out on the 2 September with sky max they said you get evening and weekend call out no so . I also have found out I have Sky Q I was talking to Sky teq who said Sky max is not recommended for Sky Q
Message posted on 19 Aug 2024 07:24 PM
Re: Sky max
That used to be the case: Sky will now supply Max to households with a main Q box and one Mini box.
Message posted on 21 Aug 2024 02:08 PM
Re: Sky max
But have found no fault on my line .
I have Sky Q with Sky Max. Router .As of 2 days everything was working. When I go into settings I go into settings Satellite Tick .Network Con Tick ..Watch Via go x Watch on Q mini BoxX. Cannot reset
Both say need you need a active broadband connection to watc Sky Q on Sky Go Which I have .
Also All my apps have disappeared
My mini Q box won't work it says you don't have the right subscription to use Sky Q mini box
Has anybody has this problem A engineer is not due until the 2 September
