Discussion topic: Sky max pods
This message was authored by: Louise8888
Sky max pods
Hi there, My sky max broadband pod is not connecting at all to the main sky max hub.. I've unplugged it plugged it back in again moved it close to the Hub added the serial number manually nothing is working... The light on the hub is just flashing white. Like it's looking to connect but nothing is happening... Anyone got any suggestions?
Re: Sky max pods
@Louise8888 if the pod was supplied by Sky call them to get the issue sorted. Pods obtained from other source s wont wotk
