Discussion topic: Loosing interest connection continuously
Message posted on 14 Sep 2025 09:54 PM
Not long 'upgraded' my broadband speed. My broadband internet connection is constantly dropping out. Working from home so this is a big problem.
Message posted on 15 Sep 2025 05:10 AM
Re: Loosing interest connection continuously
@EmmalouJ2805
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 19 Sep 2025 08:19 PM
Waiting for engineer
I am still waiting for an engineer called 4
days ago
