Discussion topic: Sky max pods
Message posted on 15 Oct 2024 11:17 AM
Sky max pods
Does the sky max pod have an Ethernet in port?
I've a cat 5 connection from the router to the wifi 'dead zone', I'm wondering if I could connect this pod via Ethernet to give me better wifi in that office?
Message posted on 15 Oct 2024 11:40 AM
Re: Sky max pods
I believe the pods actually have two ethernet ports.
Yes, that should work.
Message posted on 15 Oct 2024 12:01 PM
Re: Sky max pods
Hi, thanks for the quick response, I'm led to believe the two ports are Ethernet out to devices not Ethernet in to create a new zone in my office, have you tried it this way round?
Message posted on 15 Oct 2024 12:03 PM
Re: Sky max pods
My broadband is with BT, but I'd think the Max pods are specified as bridges for ethernet-in as well as out. All previous Sky booster models have that functionality.
Message posted on 15 Oct 2024 01:21 PM
Re: Sky max pods
It'll be delivered soon so I'll let you know how we get on, the sky tech guy didn't seem to think you could use it like that but he wasn't sure.👌
Message posted on 31 Oct 2024 03:16 PM
Re: Sky max pods
Did you get an answer to this from the Sky guy?
I got a pod today and I've tried plugging a laptop into it, but it doesn't detect a LAN port.
There's a frustratingly small amount of info about these things on the web
Ta
Message posted on 31 Oct 2024 04:11 PM
Re: Sky max pods
@Fred123456789000 as delivered the pods need a period to download firmware and optimise the connection to the hub this can take a few hours As I understand it the pods will work as a WiFi to Ethernet bridges. The pods are made by Plume but are running custom firmware developed by Comcast and adapted by Sky.
Message posted on 18 Nov 2024 04:15 PM
Re: Sky max pods
Did you get an answer to this, I have ordered a Pod as can't get wifi in an office room in awkward wifi place, plan is to run Cat 6 ethernert cable from router to Sky Max Pod to generate wifi in office room, is this possible? Does the max pod have ethernet in? if not what would the solution be?
Message posted on 18 Nov 2024 04:21 PM
Re: Sky max pods
Yes.
Message posted on 18 Nov 2024 04:29 PM
Re: Sky max pods
Thank you, so running a Cat 6 ethernet cable from router to it will generate better wifi in that area, there was some notes above which referenced the max pod only has ethernet out not in which I did not fully understand
Message posted on 16 Apr 2025 03:34 PM
Re: Sky max pods
Hi, did you manage to get things working? 😬
Message posted on 11 Jun 2025 11:47 PM
Re: Sky max pods
Hi,
Did this set up work?
I also have an outbuilding that Inwish to get internet access to. I have a Sky Q mini in the outbuilding along with a sky pod. Which in connected back to another sky pod back in the home using a run of cat 6 network cabling. This however does not work and will not offer internet connectivity in the outbuilding.
Is there anything I can do to get this in the outbuilding? With my previous (non max) set up, it worked seamlessly with the booster being connected using the cat 6 cable but since upgrading to the max set up,not doesn't work anymore which is very frustrating.
I have seen on another forum post, the suggestion of using a WAP in the outbuilding which is connected using the cat 6 cable run, with the one end being connected to a pod in the home. Would this work?
Any advice anyone can give would be much appreciated.
Thank you.
Message posted on 11 Jun 2025 11:56 PM
Re: Sky max pods
Hi mate, I'm sorry to say, it's still not working as expected. I'm still having to use an old TalkTalk router set as an access point, connected via the CAT6 cable. To be fair, this is giving me the speed I'd expect.
So, if you've got an old router, I'd suggest that...
Message posted on 12 Jun 2025 07:50 AM
Re: Sky max pods
@Bails147 the pods should wirk if connected by ethernet to the hub not to another pod.
Message posted on 12 Jun 2025 08:21 AM
Re: Sky max pods
BUT it doesn't...🥹
