Discussion topic: Sky max pod
This message was authored by: Ianmcb1962
Sky max pod
I have a sky max pod plugged in with the led indicator slowly flashing and the WiFi signal is still poor in that location. Do I need to connect it to my sky router?
This message was authored by: FLC
Re: Sky max pod
The mistake that many make is to put an extender where they need the signal. In fact it needs a decent signal to boost, so typically goes halfway between the router & where the signal is required.
Apparently they self-pair, so maybe try it next to router first to establish the connection & then move it to halfway.
Although I've no idea how it identifies your router if your neighbour should also have the Max Hub?
