22 Nov 2024 03:32 PM
Iv turned everything off and reset it and it's still not working.
22 Nov 2024 05:22 PM
Posted by a Superuser, not a Sky employee. Find out moreFirst thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
22 Nov 2024 05:29 PM
Your modem will have lights on them. These lights will behave differently, according to the problem it has encountered.
To help us assist you, describe your modem, tell us about the lights you see (and the ones that are not lit).
You can add a photo as well, that always helps us to guide you
