Discussion topic: Sky max connectivity / pod extender
This message was authored by: 0hme0hmy
I have recently upgraded to the new Sky Max hub, I now have 3 new extender pods, the newest pod arrived last Friday (today is Monday) and the signal is listed as poor to all 3 pods. I'm very tempted to revert back to my old set up, is anyone experiencing these same issues?
Re: Sky max connectivity / pod extender
@0hme0hmy the pods need a decent connection to the hub or the other pods to operate.so experiment with moving the new pod closer to the other units.
If you live in a house with solid walls the WiFi Max bundle may not be the best solution as the hub and pods communicate with a closed 5GHz signal which shile potentially must faster does not have the range of older systems that also used thr 2.4GHz band between units.
