Discussion topic: Sky keeps not working
This message was authored by: Jaf4
Hi our sky box keeps stopping from working. All checks say it's ok
have to reboot everytime
help!
Re: Sky keeps not working
@Jaf4
I'm presuming you are referring to your hub.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
