Discussion topic: Sky keeps freezing
This message was authored by Gld1980 This message was authored by: Gld1980
Sky keeps freezing
Sky keeps freezing plus there's no dial tone on my landline. Have just had everything installed on Monday. Something isn't right. Could an engineer come over to inspect please? Is there anything you can do please?
Re: Sky keeps freezing
@Gld1980  As we are all customers here nothing will happen on the back of a forum post.
Gld1980
OK thanks for the reply
 Would you know the best phone number to talk to technical support please?
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Gld1980
If you definitely need to contact Sky then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum.
Note: We’ve been informed the lines are busier than usual at the moment.
▪️I AM NOT A SKY EMPLOYEE ▪️
