Discussion topic: Sky hub
This message was authored by: Fergie6
Sky hub
My programmes films keep switching off and on intermittently
Re: Sky hub
@Fergie6 assuming other devices are not losing connection at ghe sametime and the lights on the hub dont change the issue sounds to be a poor WiFi connection to the ddevice you sre streaming to. Streaming video needs both sufficent bandwidth and a stable signal.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
