Discussion topic: Sky hub not receiving internet
Message posted on 03 Aug 2026 10:31 AM
So got up this morning to broadband hub flashing slow green,
Done what every forum.said left 15 minute and then switch off and this error occurred at 2am and still nothing has changed!
Litrally school holidays and I need the Internet
This isn't the first time this has happened and I have to wait over a week for an engineer apparently
Are there any outages in North and East of Cornwall?
Message posted on 03 Aug 2026 10:33 AM
Re: Sky hub not receiving internet
@Tonicas
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
