Discussion topic: Sky hub max LED red upon setup.
Message posted on 18 Nov 2024 10:50 AM
Message posted on 18 Nov 2024 01:23 PM
Re: Sky hub max LED red upon setup.
@JackEboy125 the red light means the hub is not connected but this is not unusual as the text often comes through several hours before the activation is complste. The work is done by Openreach and can happen anytime up until midnight. If your hub is not connected by tomorrow call Sky but it is pointless calling before then as Openreach report overnight if there are snags.
Message posted on 18 Nov 2024 01:54 PM
Thanks for the info, much appreciated. Will see what happens by tonight.
Message posted on 14 Feb 2025 09:32 AM
Hi.
I have the same problem. Received the text that it will be ready on the 13/02/2025. It is the 14/02/2025 kept it plugged in overnight. This morning was the same solid red nothing happened. Same message on the sky app.
