Discussion topic: Sky hub issues
This message was authored by: Doveside
Sky hub issues
On my sky hub i have only 2 green lights. Power and wi fi. I can not get my sky glass to work andbroadband
Re: Sky hub issues
@Doveside
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
This message was authored by: Forestwalker
Re: Sky hub issues
It might sound obvious but have you moved the broadband cable over? It has a little BT connector on the end. Your router should have 3 green lights on it, if not then you have no BB.
