Discussion topic: Sky has stopped
Message posted on 10 Oct 2026 04:52 PM
Sky has stopped
Sky to has stopped
Message posted on 10 Oct 2026 04:56 PM
Re: Sky has stopped
Do you mean Sky Broadband is not wortking ?
If so have a look at the lights on your broadband hub and try going through this:
Message posted on 10 Oct 2026 05:03 PM
Re: Sky has stopped
Mine has too
Message posted on 10 Oct 2026 05:15 PM
Re: Sky has stopped
@SamRV
If you are new to the forum or this is your first post then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Use this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that only affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
