Discussion topic: Sky full fibre gigafast +
Message posted on 19 Oct 2025 02:23 PM
Message posted on 19 Oct 2025 02:30 PM
Re: Sky full fibre gigafast +
@CainA If you're running tests over wifi you'e never going to get the same speeds as you do at the hub, wifi can't give those speeds.
Much better to trest using an ethernet connected device.
Message posted on 19 Oct 2025 02:46 PM
@CainA What speed do you get testing when you are about six foot away from the sky Hub that you have? If the service checker is working which had some issues on the CF connection to the hub you may be able to see what is being delivered.
