Discussion topic: Sky down again.
This message was authored by: Fidz1
Sky down again.
My sky is down again, no Internet no WiFi.
I have switched on and off 3 timed, you have checked it and said its OK, it is not. I have 2 green lights, one light not on at all and one red light.
Re: Sky down again.
@Fidz1
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
This message was authored by: Dan221
Re: Sky down again.
Hi i have got the same problem with my Sky Hub ..I think there is a problem with the line.
Re: Sky down again.
@Dan221
Then you need to carry out the troubleshooting in my earlier post.
