Discussion topic: Sky broadband
This message was authored by: mancity0
Sky broadband
Upgrading to full fibre 150...was expecting a new sky hub but only received a n Ethernet cable...is this right ?! Phoned up but got cut off TIA
Re: Sky broadband
@mancity0 If you currently have the sky Broadband Hub then yes Ethernet cable is all that is needed and will be supplied! Link below if you need to look at sky hubs to be sure!
Avatar for mancity0
Re: Sky broadband
@JimM1  Thank you much appreciated...difficult to navigate such problems being a technophobe ! 😬
