Discussion topic: Lack of connection
Message posted on 19 Oct 2025 07:26 PM
Lack of connection
Really unhappy with internet. Was great before but it's getting worse. Upgraded and no improvement please can this be rectified
Message posted on 19 Oct 2025 07:36 PM
Re: Lack of connection
@James504 Getting worse since when? before or after the upgrade, or both at the same time? Does sky have a history to this issue?
Message posted on 19 Oct 2025 07:44 PM
Not great before but recently getting really bad buffering, lack of connection on sky glass
Message posted on 19 Oct 2025 07:47 PM - last edited: 19 Oct 2025 07:49 PM
@James504 Sky glass and what sky Hub are you using? Also TV wired to the hub or wi-fi connected!
Message posted on 19 Oct 2025 08:35 PM
Wifi isn't that the idea behind sky glass?
Message posted on 19 Oct 2025 08:39 PM
@James504 Sky Glass is a streaming TV with all the options in it, Wi-Fi connection will NEVER be as good as an Ethernet Network connected device EVER!
Message posted on 19 Oct 2025 08:56 PM
They will probably tell you it's your fault sky are embarrassingly dreadful when it comes to fixing problems and taking accountability
