Discussion topic: Sky broadband keeps dropping out and orange light comes on router
Message posted on 29 Jan 2025 10:30 AM
Sky broadband issue, wifi keeps dropping out when i am working from home on laptop. The orange light keeps coming on the wifi router. This has happened for a few days now and i need it for work
Message posted on 29 Jan 2025 11:08 AM
Re: Sky broadband keeps dropping out and orange light comes on router
@Gareth105
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
