Discussion topic: Sky broadband dropping
This message was authored by: Nigel+Haymes
Our home Sky Broadband connection keeps dropping this morning. 3 times since 7:30am. Have run the Sky Broadband and WiFI checks and everything has a green/good status. I experienced multiple dropped connections during the working day on Monday 8 December, though yesterday was stable.
Re: Sky broadband dropping
@Nigel+Haymes
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Nigel+Haymes Do you see anything on the hub etc when it happens?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
