Discussion topic: Broadband issues
Message posted on 10 Dec 2025 11:29 AM
Broadband issues
Hi broadband keeps cutting out over the last hour very unstable payinga
lot for this service!
Message posted on 10 Dec 2025 11:38 AM
Re: Broadband issues
@Njfarmer
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
