Discussion topic: Sky broadband and phone line not working
Message posted on 03 Feb 2025 10:15 AM
Sky broadband and phone line not working,
since morning trying to connect customer service no luck
looks live no customer service exists with Sky.
Any help would be much appreciated.
Message posted on 03 Feb 2025 10:22 AM
Re: Sky broadband and phone line not working
I can't help but I am also having the same issue. Hub keeps rebooting, WiFi drops out, tests are inconclusive but can't work out how to speak to someone to get it fixed.
Message posted on 03 Feb 2025 10:48 AM
@sksu1
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
The Customer Service line is open as normal but obviously there may be a wait.
Message posted on 03 Feb 2025 11:35 AM
I am having the same issues. I have been away over the weekend and the service checker shows my broadband speeds dropped Friday and haven't yet returned. This morning we have no landline (line cord error) and broadband keeps recycling and disconnecting. I have a connection but it isn't stable enough to make work video calls.
The MySky app isn't loading for me either (i did the service checker on the website).
I have spoken with sky and the person on the other end said there was an issue with his visibility of my profile to was unable to diagnose any issue. He is waiting for it to be sorted and then will call me back to help me.
Just sharing for info if others are having broadband issues this morning.
Message posted on 03 Feb 2025 11:51 AM
I’m having issues as well. Hub has no light on for Internet but the test keeps telling me the connection is fine.
Message posted on 03 Feb 2025 12:16 PM
Have you tried the advice in post 3 above?
