Discussion topic: Sky box not working.
This message was authored by: Helen334
I have unplugged the box several times and also reset the hub but the sky box does not work. It flashes then goes off.
Re: Sky box not working.
@Helen334 which type of Sky TV system doyou have SkyHD+, Sky Q or Sky Stream? Each is quite different. If you other devices are staying connected it doesn't sound like a broadband issue.
If your TV box is faulty Sky will replace Sky Q and most Sky Stream pucks if thry are lent. However the older Sky HD+ boxes and some of the first Sky Stream pucks were sold so will not be replaced but it is worth talking to Sky
