Discussion topic: Sky booster
This message was authored by: Ol3
Sky booster
Does anyone know where i can find the power supply cable to the booster mine has broken recently and the connection upstairs is terrible
Re: Sky booster
@Ol3 Take a look and say which booster you have there are a few off them!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
Avatar for Ol3
Re: Sky booster
I have the sky broadband booster
Re: Sky booster
@Ol3 if the booster came from Sky they will replace the unit if you call them. If you bought it elsewhere you are essentially stuck as these units all belong to Sky. A sesrch for Sky Booster SE210 power cable gives results for third party power supplies that are claimed to be compatable but it is at your ridk.
Re: Sky booster
@Ol3 With @Chrisee on this one the search throws up far to many THAT WILL NOT work as the barrel size is wrong, but it is a 12VDC 1.42A 17W PSU with a 4.8/1.7mm barrel connection. If i can find an amazon one that is direct then will post for you, but it may just have to be one with the multi connector adapters to fit!
Sky will replace the unit possibly if you still have it on your package, i know mine is not for sure so would not expect that!
Closest that Amazon have that will work but barrel adapter is required!
SZZKtech 12v ac adapter power supply charger with 8 DC plug tips ac to dc12v 2a 1.5a 1a 800ma 600ma ...
