03 Sep 2024 03:02 PM
I upgraded to Sky Glass with Sky Broadband Ultrafast1 with Sky Wifi Max but if we are watching /streaming TV the internet on my laptop/phone drops. Testing shows everything as fine but its definitely slower than before we updgraded. Very frustrating!
03 Sep 2024 03:21 PM
Posted by a Superuser, not a Sky employee. Find out more@NN2 Do you have weak Wi-Fi in the property?
03 Sep 2024 03:47 PM
Exactly the same has happened to me
continually drops
frustrating
03 Sep 2024 04:02 PM
It seems to be only when the Sky Glass TV is on. We didn't have issues like this on the previous Sky broadband (but then didn't have the Sky Glass either)
03 Sep 2024 04:52 PM
Posted by a Superuser, not a Sky employee. Find out moreWHen you say the connection drops on your laptop/phone, does it completely disconnect from the WiFi signal or just stop loading anything?
03 Sep 2024 06:25 PM
Keeps trying to load
my tv too is going around and around trying to load
03 Sep 2024 07:34 PM
It stops loading anything (even something simple like Google homepage or my outlook tells me it is offline) and then when I look at the wifi on my laptop it shows as either disconnected (globe icon) or 'no internet'.
We aren't having any issues with the streaming on the TV so assume that is taking it all but I was assured that it would be more than enough to cope with all normal household use.
04 Sep 2024 10:41 AM
Posted by a Superuser, not a Sky employee. Find out moreDo you have any sort of boosters, extenders connected to the hub?
05 Sep 2024 08:59 AM
No we don't but it is only a small flat so am always working very close to the hub
10 Sep 2024 10:09 AM
Posted by a Superuser, not a Sky employee. Find out moreDoes the My Sky app show any issues when you run the test?
Its difficult to diagnose on the Sky Max hub because there isnt any router stats.
