Discussion topic: Broadband Upgrade
This message was authored by: ClockTear
Broadband Upgrade
Hello, It appears the Ai assistant couldn't do the trick and i ended up among all of you lovely people.
Without much to triffle over, i would like to upgrade my broadband to the maximum capacity i can quite possibly find myself in good fortune of. That is essentially the Wifi Max package. Now, although it is advertised as the best option (obviously) i would like to know more about the speed boost in and of itlsef from superfast to max. Understanding that obviously there is a (gigafast?) which may not be an option to me i would like to cover numericals of the upgrade i can facilitate and be cheeky enough to ask that since i have a silver member discount on the horizon is there a chance i can apply the discount in the upgraded package or is that a no-no?
Thank you for your time and effort at any capacity. Ta.
Re: Broadband Upgrade
@ClockTear
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is available.
@ClockTear
Note Sky doesn't discount broadband pricing based on VIP status.
