Discussion topic: Sky WiFi not working
Message posted on 01 Jan 2026 07:18 PM
WiFi has been really poor recently constantly dropping out although it says there is not problems with it. Been through all the troubleshooting still not fixed it
Message posted on 01 Jan 2026 07:20 PM
Re: Sky WiFi not working
@Swalsh861
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
