Discussion topic: No wifi
This message was authored by: Kristi2
No wifi
WiFi is playing up, has been for a while now (2 months approx). Keeps turning on and off past few days has been worse
Re: No wifi
@Kristi2 How do you know it is turning off and on are all wireless wifi devices affected if you know?
Avatar for Kristi2
Re: No wifi
Yes so there are 3 mobiles in our home, 1 iPad, 1 Xbox and my laptop for work. They all loose wifi regularly at the same time.
Re: No wifi
@Kristi2 Is there anything connected on the Ethernet device wise, what sky hub do you use and do you see anything if you are looking at the sky hub.... What is needed to be done to get you all back online and working again!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
