Discussion topic: Sky WiFi no internet
This message was authored by: Lucius85
Hi we're getting no connection through our WiFi hub
Re: Sky WiFi no internet
@Lucius85
If you mean your broadband is down, at that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned by 7am use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
