Discussion topic: No broadband
Message posted on 30 Apr 2025 07:16 AM
No broadband
This is the 4th time this week I have no broadband connection. The test is saying your now connected but I am not.
Message posted on 30 Apr 2025 07:30 AM
Re: No broadband
@Broadband_
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 05 May 2025 12:20 AM
Re: No broadband
Thank you for the help.
