Discussion topic: Sky WiFi max hub
This message was authored by: Hp0018
Sky WiFi max hub
I upgraded to sky wifi max, is it meant to replace my old sky q hub or is it an add on, cause I don't have another master socket terminal to put it in upstairs, which is where I wanted the sky max hub and downstairs the sky q hub, but I think it's meant to replace it.
Re: Sky WiFi max hub
@Hp0018
It's a replacement: only one ISP router can be installed use at a time.
