7
This discussion topic has been answered Discussion topic: Sky WiFi Max
This message was authored by: jasonuk1975
Sky WiFi Max
Thinking switching to sky BB and the max package.
I have ring cameras on outside of building and needing extenders to connect at present with BT.
Are the max pods decent and give a good signal  ?
This message was authored by: mormegil Answer
Re: Sky WiFi Max
I changed my max hub ssid and password to match that of my old router and it connected with no problems when it powered up
Re: Sky WiFi Max
@jasonuk1975
One point to note is that Max pods are WiFi 5 rather than WiFi 6.  The various Sky WiFi 'guarantees' specifically exclude outside spaces, so it wouldn't be possible to claim for that purpose.
Re: Sky WiFi Max
Re: Sky WiFi Max
@mormegil Are your BT white Whole home wi-fi or the Black Complete wi-fi, white should work fine, black is a NO NO!
Re: Sky WiFi Max
If you state when ordering that you the bt boosters then the sales agent should also request the first sky booster to be sent at the same time
Avatar for jasonuk1975
Level 3 icon
Re: Sky WiFi Max
Yea would need to a device in the room beside the camera 😉
Level 3 icon
Re: Sky WiFi Max
Did you have extenders already and did they connect up automatically ?
Level 3 icon
Re: Sky WiFi Max
I have a Bt plug in 600 extender in one room and a RE200 tp link in the other.
