Discussion topic: Sky Ultra Fast Broadband “hangs”
This message was authored by SH123HS This message was authored by: SH123HS
I have sky ultrafast, installed about 2 months ago. Regularly when opening websites the page hangs at about 30% open. The page eventually opens but only after circa 20 secs.This occurs irrespective of the amount of devices on the Wi-Fi and irrespective of the band width being used. Openreach have fitted a new master socket in the house but this has not changed anything. I have run multiple tests on my speed and router and everything is reported as ok. Can anyone offer any advice please.
This message was authored by Dallen9798 This message was authored by: Dallen9798
Re: Sky Ultra Fast Broadband “hangs”
If you're using an Apple device, try turning off Limit ip address tracking & private relay off in settings of the device, this usually helps.
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
SH123HS
That has definitely worked! Thank you.
