Discussion topic: Sky Telephone Wire
Message posted on 12 Jan 2026 11:18 AM
Sky Telephone Wire
Hi, the cable connecting Sky to my home is pulling the cladding away from the front of my house and we have found birds are now building a nest under there, who can I contact to get help with this?
Message posted on 12 Jan 2026 12:39 PM
Re: Sky Telephone Wire
@Lauramansell the cable does not belong to Sky and is more likely owned by Openreacch whose network Sky uses. As you cannot speak to Ipenreach direct call Sky as they can get Openreach out. The birds nesting is not something they can stop but they can hopefully secure tge cable for you.
Message posted on 12 Jan 2026 01:22 PM
Thanks but how do I contact Sky?
Message posted on 12 Jan 2026 02:07 PM
@Lauramansell Dial 150 on you landline, pass security and NO if they try to direct you to the Forum, then hang on until you connect to a Customer Service agent!
Message posted on 12 Jan 2026 02:13 PM
We don't actually have a home phone, how else can I contact them?
Message posted on 12 Jan 2026 02:38 PM
You do have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine.
If you buy a cheap handset in the future you only need to plug it in when you need to call Sky (by dialling 150 which is free) if there's an issue.
These are the current methods for contacting Sky, and some will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed at a weekend.
Message posted on 12 Jan 2026 03:24 PM
this just sends me round and round in circles, is there a number for general customer services as 150 will not work for me as I do not have a Sky mobile or landline
Message posted on 12 Jan 2026 03:29 PM
@Lauramansell YOU do have a landline, every sky system has one, if not then you do not have sky!
Message posted on 12 Jan 2026 03:32 PM
As we've said, you do have a Sky Talk landline.
Message posted on 12 Jan 2026 04:01 PM
OK, to be more exact I do not have a physical phone to connect to the landline, there must be some other way to speak to them
Message posted on 12 Jan 2026 04:14 PM
Alternative methods are those described in post 6.
