Discussion topic: Sky Stream Hub Issues
Message posted on 01 Oct 2025 08:03 PM
The Sky stream hub is having connectivity issues where programmes won't load and it just says there's a technical problem.
everything has been rebooted several times but still no picture or program will display or play.
wifi is working fine as Netflix and YouTube works ok.
What is the cause of this problem and how do I fix it.
Message posted on 04 Dec 2025 12:48 AM
Re: Sky Stream Hub Issues
Not to been a les to use sky upstairs. Thought the new package would solve this. Just made things worse. Can't even get tb downstairs
Message posted on 04 Dec 2025 07:34 AM
@EileenWilliams What was done to cause this, you mention a new package can you say what and also is the problem that you have only with getting TV at both the locations but everything else is working? As per your heading is everything TV wise now new streaming mode Equipment ie sky Puck's!
