Discussion topic: Sky Router
This message was authored by: DMJEN
Sky Router
I think I have a problem with my Sky Router. Device connection is intermittent and I am being kicked out of devices within a few hours. I have checked broadband speed, connection etc and all are good.
Work laptop and Sky Q main and mini boxes are affected. This has been happening for 2 weeks.
any ideas ?
Re: Sky Router
@DMJEN  Black or white router from Sky? How are all these devices that you have connected to your router. wired or by Wi-Fi?
Avatar for DMJEN
Re: Sky Router
Hiya, thanks for responding. All connections are Wi-fi and router is black. I shall try a hard wired connection and get back to you
Avatar for DMJEN
Re: Sky Router
Hard wired works
Avatar for DMJEN
Re: Sky Router
Hard wire connection is also intermittent. Booted out twice in last hour. Do I need a replacement router ?
Re: Sky Router
@DMJEN Have a look at the link and say which hub you see!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for DMJEN
Re: Sky Router
Sky broadband hub
Re: Sky Router
@DMJEN When it is as you say hung up and offline, what do the 4 hub lights look like, and what is the method do you use to recover and get back online.
Are you prepared to live without your sky Q for a little while to fault find what may be going on! Will possibly be killing your mini's so hotspot wi-fi about may suffer badly, so you are aware!
Avatar for DMJEN
Re: Sky Router
Hub lights are always green.
Why cant sky just send a replacement router 😳. I been messing about with connecting/ re-connecting per the sky help advice for 2 weeks. I de-activated all devices bar one and it still goes down.
Avatar for DMJEN
Re: Sky Router
We are now only hard wired to one device and we have no internet. If it's not the router, what else
can it be?
Re: Sky Router
@DMJEN You need to call sky, they will run a diagnostic from there end, what they find determines the action that will be taken, that is all that can be done, if you feel you have exhausted all at your end. Good luck with it all.👍
Avatar for DMJEN
Re: Sky Router
Now I just need a person to answer at sky and not an automated message that eventually disconnects me 😳
Re: Sky Router
@DMJEN It's a patience game, hope that your one wired device is NOT a sky Q sat box!
