6
This discussion topic has been answered Discussion topic: Sky Router blocking NordVPN
This message was authored by: Graeme44
After 15 months using NordVPN, my Sky router has stopped allowing access to any and all NordVPN websites. Why and how do I resolve?
This message was authored by: Sky013 Answer
Re: Sky Router blocking NordVPN
The same thing happened to me.
I spent ages trying to get my laptop to work with NordVPN as I couldn't get I to login. Eventually, I resolved it by signing into my sky account. Then went to broadband shield, then clicked on exceptions and input 'nordvpn.com'. I have had no trouble connecting since doing that
@Graeme44 check the setting for Sky's Broadband Shield as tge lower ages will block VPN traffic. Easiest to do is via tge My Sky app product options.
Avatar for Graeme44
Thanks I tried the age related block but no parental controls are active. I also tried turning off IPv6 as suggested through a Google search. Neither options have mad a change!
@Graeme44 really dont knowxwhat to suggest beyond a reboot of the hub leave it off fir an hour should forcexa changecin IP address. Given NordVPN is quite popular and there dont appear to be other posts I doubt it is a system change but given the introduction of the online Safety Act on 25/7 it is possible something has changed but normally Sky tell us about changes caused by legislation.
Puzzling.
Avatar for Graeme44
Thanks again. I'll try the 1 hour off and reboot.
This message was authored by: DaveS71
Legend,  worked for me was going mad trying to resolve this.
