Discussion topic: Sky Router Login
Message posted on 24 Mar 2025 08:30 PM
Sky Router Login
Hi,
Simply can't remember the sky router username and password (for admin settings).
How does one get around this?
Many thanks.
Message posted on 24 Mar 2025 08:40 PM - last edited: 24 Mar 2025 08:42 PM
Re: Sky Router Login
Which router?
Later one's it's printed on the router, same as WiFi password. If you've changed it & forgotten what to, you'll have to factory reset.
Message posted on 25 Mar 2025 06:40 AM
@Curious the username is always admin tge default password for the old flat stylehubs is the word sky.otherwise its the degfault wifi password on the label. See https://www.sky.com/help/articles/find-and-change-your-wireless-password for more.
