Discussion topic: Sky Q mini box to boost WiFi
This message was authored by: Adycar
Just changed router to Sky Max but my Q mini boxes are not boosting WiFi any more. Changed the setting to "on" but still not working. You can't speak to anyone at Sky and I don't know what to do next other than return the router and go back to my old one. Help please!
Re: Sky Q mini box to boost WiFi
@Adycar The old SR203 sky Broadband Hub works well when sky Q mesh connected, the sky MAX hub does not so it is a way different setup. If you have Q would keep the old and get the sky Max back, sky will NOT allow the change back from there end, it's once you go Max you never go back! The links below if you wish to soldier on and try!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Avatar for Adycar
Many thanks - I've now returned the Max hub and gone back to my previous setup. All back to how it was - phew!
@Adycar Glad it all worked out, the sky Max though theoretically a faster Hub, does take a little persuision to get it all working and it's one off those out the box it works or causes havoc! Perfectly working systems prior is a good leave it all alone!
