Discussion topic: Sky Q and virgin
This message was authored by Shazzy71 This message was authored by: Shazzy71
Sky Q and virgin
I was having trouble with my sky q connecting to my virgin broadband so an engineer came out and left me a sky broadband hub fir my sky q but there is no password with it help!
Re: Sky Q and virgin
@Shazzy71  A sky hub will not work on a virgin media broadband connection.  Or are you saying you now have Sky broadband as well?
The wifi password is printed on a label on the back of or underneath he hub.
@Shazzy71
That was probably a Sky wireless booster, not a Hub.  You connect the booster to your Virgin router (preferably using ethernet cable) and then the Q box to the booster by pressing the WPS buttons on both.
Shazzy71
Hi Timmy,
Thankyou I will try that.
@Shazzy71
Certainly worth a try.  If it's a white box then it's definitely a booster.
